I just installed Solid Works 2008 SP3.1. I also installed
PDMWorks on to our server. I can connect to the PDM server using
Solid Works Explorer but it says I can only check in solid works
files through the Add-In inside Solid Works itself.
However, the PDMWorks Add-In does not show up in my add in menu. Is this add-in an extra option I have to buy or did I not install properly?
Shawn
Shawn
yes, my VAR was very helpful. actually ended up doing a ' repair' from add/remove programs, by selected to install the missing plug-in component. BUT, first I had to de-select the SW explorer component to uninstall SW explorer(with the PDW client) then re-ran the 'modify' program to re-select the explorer and PDMW SW add-in client at the same time. hope that helps. no idea why that worked but it did!
I followed the advice, it didn't quite work, however I was able to capture an error message that I sent to my var to help solve. (which I'm sure they will be able to).
thanks again
