I have a question about circular pattern of surfaces and problem to knit these surfaces:
I have a loft surface that I would like to use for a circular pattern. Once I have done the circular pattern, then I can't knit the surfaces, same problem with mirror. I used circular pattern/mirror of bodies.
When I draw all the profiles and loft all the surfaces then I get of course one single body but this is much more work. If I do a thicken feature of the body and then do a circular pattern, then I can merge the bodies.
Why can't I do that with a circular pattern of surface, without the thicken feature?
Thanks in advance for your help,
any help about circular patter and mirror in general is also welcome!
Regards,
Ariane
Regards,
Ariane
I tried mutual trim and now the result is one single body. I selected the 2 surfaces for "trim tool" and the same ones for pieces to keep. How does actually the mutual trim function work? Does it automatically knit the surfaces?
Yes.
