Hi fellow CAD people,
I'm using the mold features to make mold cavity's, but i have a problem.
It fails to close the holes with the "shutt-off surface" feature, so i closed them manually with surfacing.
How can i combine the new surfaces after knitting them, with the solid body, so i can make a good tooling split.
greetings,
Stefan
greetings,
Stefan
Also, you can use "delete face" to delete all the faces you do not want (thus making the solid body a surface body), then use the knit tool to knit all the surfaces together. Just make sure to select "convert to solid" in the knit properties.
