Hello guys,
I'm running frequency study, for some reason I get this wierd message after defining material and restrain:
"STOP: Maximum node number exceeds the limit"
when I'm trying to run the solver.
any ideas?
P.S. I'm a complete newbie on cosmos, I was just following the tutorial and I got stuck with this problem. My settings might not be configured correctly.
Thanks in advance.
any ideas?
Thanks in advance.
Are you using Cosmos/M? If so, the solvers there have a strictly predefined total nodes limit. If not, what version and SP are you using? Are you using 32 or 64 bit Cosmos? What tutorial do you mean you are working with? All should be posted here to let us determine what is the problem.
Regards, Basil
