Forging Processes?
Question asked by Henry Belch on Apr 16, 2008
Latest reply on Apr 30, 2008 by Henry Belch
Can Cosmosworks Advanced Professional provide accurate forging simulations for heated non-linear materials with initial transient convective and radiation cooling and then at die contact change to transient conductive cooling with changing non-linear material properties and provide associated die forces/stresses? (For instance assume I have calculated the temperature dependant transient convection and conduction equations - and can I apply them to the model?).
Also, can it solve thermal shock problems (for instance quenching steel alloys in oil or 2 Gev proton beam hitting solid target material) and provide transient stress wave propagation through the material?
While I'm here, can it perform subsequent analyses which simulate the removal of a load after a body has been highly plastically deformed to determine the total elastic springback while retaining the plastic deformation at zero load (and plastic strain distribution)?
Also, crack initiation and propagation. Can you set failure criteria in the material which define volumetric element removal after adaptive meshing under highly stressed conditions for elements of a particular size (say, for instance when an element in a transient dynamic stress analysis adaptively reduces in size to below 0.0001" and the average stress level in that element exceeds a set value - ultimate strength at some predefined temperature). Remember, maximum stresses are not always on the surface...
