Hi Friends
When I am doing the cable routing I am getting the issue in the diameter of the cable. I am running a bunch of cables in one route and the routs are splitted to the different connectors. But after splitting into the connector the diameter needs to be changed and shown depening on the number of cables and dia of the cable. Whereas in my model it shows as the less diameter sometimes same diameter. When I am trying to edit the feature I am able to see the correct diameter. After editing it goes to the wrong diameter. Is it possible someone to help my problem
Check the attached image for more clarity
Regards
Prabhu
SW 2007 SP 4.0
Regards
Prabhu
SW 2007 SP 4.0
You picture didn't come across. I think I understand your problem though. What you need to do is as follows:
1. edit component on your harness assembly. (this will put you in your harness file as a sub-assembly of the main assembly.
2. delete the part file that is the harness route.
3. edit route (this will recreate the harness)
4. exit the cable route (this should now show the harness diameters correctly.)
5. save over the old route part
6. exit the edit component command
What seems to happen is after you edit your route, the part file doesn't update, so by deleting the file it gets recreated with the latest changes.
