I've used SW Routing but never SW Electrical and I have a few questions for the folks who used it.
Do you have to have input from both the EE and ME to complete a Electrical project? I guess what I'm trying to find out is if we purchase this software, will the MEs have to create electrical circuits to create wire diagram or the electrical information can be imported from Cadence (our electrical software) into SolidWorks Electrical.
I am 'applications engineering' - I do both the 2D and 3D:
1. Create 2D project, create schematic - this process requires associating manufacturer parts with each symbol on the schematic.
2. Create 3D assembly - this process requires building a normal 3D assembly, then 'associating' each 2D symbol with a 3D component.
3. Route - click of a button, wires pop up. The more I play with this, the better I get at having a good initial setup, and the faster it goes.
The software is VERY picky - you have been warned:
4. 3D parts require setup for routing (much like CPoints from SW routing tool, but not the same so I don't think parts will carry over).
5. The 2D and 3D setup must be identical - hard to explain without giving a class but basically connection 1 in 2D must be connection 1 in 3D - it can be tricky to keep things straight sometimes.
As I re-read your question I see a quicker answer:
I have had no luck with importing anything into SolidWorks Electrical - even simple dxf symbols do not want to transfer correctly. Also, every wire, every symbol, every part in a 2D schematic within the Electrical software has a mountain of information behind it.
For example - a single wire:
This is just one wire - we have dozens of these set up, each with its own data used to drive both 2D design checks as well as 3D routing data (i.e. minimum bend radius, color, etc.)
