I am in an assembly and select edit component to add holes referencing another part. The hole wizard will not select the center of the existing hole of mated part. I have used it in other assemblies and it worked. What am i doing wrong or parameter missing.
I have a sketch where I draw circles at the hole location, I close that sketch and add my holes with the Hole Wizard and sometimes I see what you're experiencing, my work around is I'll drop the point close to the circle and then make the point concentric with the sketch circle. Most of the time it'll work, but if you have a lot of components and you're in an assembly, my guess is that the Hole Wizard picks up other part vertex's, instead of the hole center point..
