Hi guyz,
I have been running the simulation for heatsink and recieved errror prompt "SOLVER ABNORMALLY TERMINATED! Please contact the support service". This particular message appears when the iterations reaches 851. I tried changing different pc, but to no availability. During the simulation, some of the goals that I have set are invalid. Are they prone to this error message? Anyone can assist?
Thanks!
Calvin C.
Thanks!
Calvin C.
remove the invalid goals, run the simpler simulation and see what will happen.
Regards, Basil
Say if I needed the surface goals in order to generate the results for validating, eg. the temperature needed at different location on the surface of the heat sink. Besides using the surface goal, is that any other alternatives to obtain the temperature at the nodes? By the way, I have used the refinement level at level 1, but the problem still persist.
Bill-yes, I'm getting a memory error, which I presumed there are too much nodes in the model itself. However, I am trying out to figure out how to decrease..
Regards,
Calvin
Have Fun
Bill
Calvin
Good Luck
Bill
