A new EPDM system is being implemented and I wish for it to follow a very specific workflow. When the file undergoes a transition from "State A" to "State B" I want the file to be moved from its current folder "Folder 1" to a new folder "Folder 2". Is there anyway this can be done on EPDM?
Hi Matthew, if you have access to the SolidWorks Knowledge Base, check out Solution S-057734
Moving a file as a file changes state is not possible out of the box, but is possible through the EPDM API. The solution referenced above, has an API example from SolidWorks on how to achieve this.
Prasad
