I get:
vault error :102
"You have no permissions to change the document properties!"
"Failed check-in of document "XXXXX""
"Check-In aborted!"
I did not change anything at check in, yet it keeps preventing me.
Could there be something wrong with the part template or does anyone know what I am doing wrong? I am the administrator and have RW access to all projects, I created the part from scratch using the standard template...
vault error :102
"Check-In aborted!"
Ports 20000, 30000 & 40000 are set-up, IT worked with CATI and Solidworks rep. to set-up, so I am not sure what else is the problem...
help!!!!
I also had the IT guys give me read, write and modify access to the vault folder temporarily and that did not work either...
When they find out what is going on I will post it here...
(no matter how personnally painful it may be...
ie: I forgot step 1 in the set-up...)
I forgot to add the read/write access to the lifecycle levels in the PDMWorks Workgroup Vault Admin Lifecycle tab...
The Heckling may now commence...
