I am just making a simple piece of sheetmetal with a pressed nut. I want to locate the centre of the nut at a certain distance from the edges, but it seems that is not possible with the available mates. Can anyone explain how I would locate the nut where I want it in the picture please?
Hello Jacob,
If you can use planes and then use a normal distance mate.
If you have revolved around vertical/horizontal line passing through origin, you can use top/front/right planes to mate else you can also add planes to nut passing through the axis of nut.
