EBElizabeth Bailey06/04/2008
Hi. I am a TOTAL newbie to SolidWorks (less than a week in
and only CAD as a background). I am trying to learn SolidWorks on
the fly while creating shop drawings for a steel fabricator. I am
getting a handle on the very basics, but have run into a problem I
can't find a solution to, and it happened in an already created
part as well as in a brand new part I created. I have sketched and
extruded a wall, then sketched lines for weldments (angle iron) on
the wall plane and extruded and moved those off the face of the
wall to allow creation of anchor plates on the back of the iron.
The trick is, the angle iron runs at an angle down the wall - it is
not parallel to the floor plane. Now I am trying to create the
plates on the back of the angle iron, but when I create a new
sketch for the extruded plates, I can't get my rectangles defined.
Because the rectangles are underdefined, I can't create an
association between them and the angle iron, and I need the plates
to be parallel to the iron. I am using the commands create new
boss/base, then selecting the plane on the back of the angle iron
to sketch on, then sketching the rectangle on that plane, then
using the smart dimension tool to define the size of the plates,
but the rectangle stays blue and won't create the association I
need with the dimensions. I have messed with some options in the
program, primarily selecting custom units and setting dimension
units to feet and inches, but otherwise I haven't played too much
with settings (some, but not too much - I can't help but push
buttons sometimes...). The killer is, I was working in an already
partially completed part where I HAD made this work, then as I went
on it wouldn't work for me again, so something in the drawing or in
my process changed midstream. Because I couldn't get it to work, I
recreated the entire part (hours of work) and now it won't work at
all in the new drawing. I can't find any answers in the usual
places - can somebody please have mercy on me and HELP ME?!?
Thanks!
