I have an assembly in which there is door that pivots around an hinge. There is an angle and a rod that changes value as it goes from open to close position. Is there any way, that solidworks will record the values of these dimensions at an interval and give me the list as output. So for example at the open position the angle is 0 and in closed 90. I need to know what the angles are through out the range of the door motion.
Fariz
