Example: Not allow *.sldasm to be created under the \swlib\ directory
Have you considered doing so through a workflow argument?
Couple options come to mind:
1. If the PDM file "category" doesn't fit into a workflow permission set, then a file can't be added into that workflow. If there is no other workflow available for the file to fit in, it shouldn't be allowed.
2. A Workflow transition argument would make users have to find a new location for file.
Using workflow and categories you can prevent them from checking a file in based on the file type but you cannot prevent them from saving the file into a folder. Kind of the same thing but not a true solution to your original question. I have folders that people have no permissions on and they still save stuff in there occasionally but they can't do anything with it after that.
