Hi
This is an variant of another thread inside here, "following a closed path".
However; my vague idea was to use a modelled frame (A skid with some equipment on; the object to check), place this frame on a "floor" and under this , attach a "ring", through this ring a 3d sketch/ line with horisontal/ vertical bend, if this line is pulled in a determined speed, in horizontal movement, the floor, and the frame will (have to) move like during a simulated earthquake....
If I have understood this correctly then, I then can check the stress in the design, the legs, the stiffeners...?
Or am I just influenced by too much heavy medication now...?
Any/ all ideas will be appreciated. But please restrict ideas to the Cosmos program(s) that is included in the SW premium package.
In the SolidWorks premium package, you have no realy way of modeling the response to an earthquake type vibration. In COSMOSMotion, you can give an osciallting displacement as a function of time to mimic the movment, but the parts are rigid (ie they do not deflect). You can look at results at given time steps from the motion simulation on individual parts, but you will not get the true response of the entire structure. It will most likely underpredict the stress and deflection since at the extreme travel of motion, the actualy movement of the parts will not be cumulative through the struction.
To be honest the best was is to model this is as a dynamic analysis in COSMOS Advanced Professional. This product is tailored to this type of analysis where you can provide excitation via displacement, velocity or acceleration and observe the response of the structure as a function of time.
So, probably not the answer you were hoping for, but the reality.
Cheers,
Ian
