BRBill Rose03/04/2008
I cannot use CTRL-TAB or the menu to browse open documents.
All I get is a one or two second look at the dialog before it goes
away. Holding the keys down makes no difference. Using the Window
menu does the same thing. Normally I'd just do it the old way but I
can't because once I get more documents open than the Window menu
will hold and the bottom of the list shows "More", that selection
takes me to the same fleeting dialog.
Also, when I use this command and the dialog dismsses the open active file will toggle between the first two listed. This is a major problem (one of several). I'm on 2008 3.1
Thanks..........Bill
