I have an overlay that I managed to get the company logo attached to as a decal.<br /><br />This overlay is part of a small assembly, which then gets assembled to a larger assembly.<br /><br />The problem is that the decal disappears when I open both the large assembly and the smaller sub-assembly. It remains on the part at the part level.<br /><br />To make it even more interesting, the decals "DO" show up on the large and small assemblies only when the part file is left open. <br /><br />What is going on here? <br /><br /><sarcasm on> And can we possibly make this any more difficult? <sarcasm off>
Is your drawing view set to shaded display?
I just had this problem happen to me last week. I dont know if the problem has been solved with latest version (i am on SP2008.2 and too lazy to upgrade). The issue i had was that the part with the decals was buried within several sub-assemblies. When i rendered the main assembly, the decals would not show up even though they were visiible in the tree.
The solution that i used was to drag (using the design tree) from the sub-assy to the main assy. After i reloaded and the decals showed up, then i re-drug the part down to its original sub-assy. THis seemed to fix the problem.
