We have an big issue with our PDM Workgroup vault.
A quick description: We modeled a 4" square plate with 2 holes spaced at 2.00 inches and done a drawing of the part. The drawing and model are in the vault.
If the part drawing is opnened using the vault viewer the dimension between the holes is NOT 2.00". The dimension is incorrect at say 1.88". There appears to be no reason for the bad dimensions and it's happening on several different dimensions. If the drawing is opened using SolidWorks the dimensions are correct.
This appears to be caused by the vault upgrade we did converting to 2007, but we are not sure.
Any ideas??
Any ideas??
