how do I add this nacelle
Question asked by Jerry Watts on Jun 2, 2016
Latest reply on Jun 2, 2016 by Paul Salvador
I'm trying to stuff a Vacuum cleaner motor in a custom shell that doesn't exactly fit.  I need to cut the back out a bit and create a nacelle to cover the motor.  I could use some help.  I suspect this should be easy.
I tried to attach the assembly that I have so far, pack-n-go zip file, but get the message "file is too large".  How do I make it smaller?
Attached is the normal shell, Part-59;
Shell as cut so I can stuff the vacuum motor in it, 59 Domel.
Nacelle approximation, Nacelle Domel.
I would like the edge of the nacelle to follow the surface of the shell just .1 outside the 10.3" cut out.  It needs to have about 3 deg draft and clear the motor by .1".
Haven't been able to figure a way to make it happen.  If anyone knows and can explain of point me to a You tube vid, that'd be great!
Jerry Watts
Here's a couple jpg's of the shell w/t motor it, just for perspective.
