Josh Ormsby
REV Table changes on Check-in
Discussion created by Josh Ormsby on Mar 21, 2008
I'm working on setting up PDMWorks and thought everything was OK, but I encountered a problem with the REV Tables on some drawings.
During 'check in' the correct REV level was set, and "Initial check in" was entered in to the 'Description' field. Some drawing had a new row added to the REV table with this information filled in (+the correct date too). Several though had the bottom row edited and the 'Description' field was overwritten with "Initial check in" (without the correct date).
I checked the Vault Settings and the 'Number of visible rows' is set to 10, but none of the effected files had more than 5 rows in the table.
Any ideas about what's going on?
Josh
