I want to draw a centerline between 2 curves like shown in the picture. But i got no idea how. Is there a function in SW who can do that?
Or maybe someone got a idea how to sketch it fast because i got an entire contour to do?
thx
thx
Create a parallel plane 1" above the plane your splines are on.
Create a sketch on this parallel plane.
Select one of the original splines and do a Tools>Sketch Tools>Convert Entities. Exit out of this sketch.
Create a loft between the not converted spline on the first sketch and the spline on the second sketch.
Create a second parallel plane at 1/2" from the first.
Create a sketch on this plane. In this sketch insert a Tools>Sketch Tools>Intersection Curve, picking the lofted surface. This should be your midspline.
