Does anyone out there know how to trouble shoot the error:
Insufficient Data in Results File? I am trying to analyze a pull
test fixture made up of a 12' x 4.5' base of I-beams and a thick
plate with a shackle mount attached and braced with I-beams cut at
45 degree angles on either end. These add up to 13 total parts. An
80,000 lb load is applied to the face of the hole in the shackle
mount and the bottom of the base I-beams are restrained.
I successfully analyzed a smaller assembly which did not include the I-beam base, only the plate, the shackle mount, and the I-beam braces. I have tried making these as one sub-assembly and the base as another as well as all of the parts in one assembly but I keep getting the same error.
Everything goes along fine until I click on my results. Has anyone been able to overcome this issue?
Mike
Mike
Thanks for the response.
It actually ran all the way through without error, but when I clicked on Stress results I get the Insufficient Data in Results File error. It doesn't crash it just doesn't give results.
Using an alternate solver sounds like a good idea but I actually was able to get results by running it again with Draft quality mesh although Solidworks crashed a couple of times.
By the way, I am running an Intel DualCore Processor at 1.80 GHz, 2.00 GB, and 20 GB of allocated hard drive space.
Mike
