Is anyone out there managing CAD files other than SolidWorks with PDMWorks Enterprise? I know that PDMWorks Enterprise is a good PDM for SolidWorks data but we have a lot of 2D CADRA legacy data and a couple of years worth of 3D data UGNX. Storing this data in three different locations has it's limitations. I know it is easy enough to bulk load the 2D data into PDMWorks and use check in and check out. It's the 3D UGNX data that concerns me. I'd like to maintain the relationships between the assemblies, parts and drawings.
Dave
David Keith
CAD/CAM Support
Cobham Defense Electronic System - Kevlin Division
Methuen, MA 01844
Dave
David Keith
CAD/CAM Support
Methuen, MA 01844
Can you briefly outline how you manually create links to non SW data in PDMWE? I have been unsuccessful in diggin up this procedure from any of the documentation. My interest is in linking installation or operations manuals to the assemblies which they refer to - thereby helping ensure that they get updated when the parent SW assy is modified.
One forum poster's suggestion was to use the design binder in SW, but that relationship does not seem to pass to PDMWE...unless I am doing something wrong!
Thanks in advance,
Spencer
Since saved BOMs are not automatically linked to the assemblies from which they are generated from, I would like to be able to link those as well. Ultimately reference them in a workflow too, since without the link it is possible to update an assembly and leave the saved BOM outdated (which is where ERP gets its data from).
Spencer
The design binder is a nice tool, but IMHO has little value if you use your PDM system correctly...because the documents contained are not searchable.
Saved BOMs are in a way linked to their assemblies. Go to the BOM tab of the assembly and find the saved BOM in the list of BOMs. This is probably another topic, but by design, saved BOMs are supposed to be a snap shot of what the assembly looked like at a chosen point of time. I don't think they are supposed to update automatically.
If you want "hot" BOMs you want a calculated BOM, not saved.
Regarding the BOMs (and I think this is still on-topic), consider the following situation:
We sell some 'commodity' items in addition to designed products. Since we brand those products (and packaging), we must document everything from the master carton and labels down to the parts themselves. Cable-ties, for example...a cable tie has a 3D 'representation' done in SW to ensure that our supplier sends the correct configuration and length. There are 100 of these in each retail branded bag, 25 bags per subcarton, and up to 8 subcartons to a master carton. With boxes, labels and all, that's a total top-level SW assy with 20,418 components in subassys (even large assembly mode has difficulty with this). The newly added BOM functionality allows me to take and place one cable tie in the 100/bag assy (which reduces top-level components in sub-assys count to 618), and adjust the quantity from one to one-hundred and save the BOM. Saved BOMs are what will pass to ERP (SAP implementation in third quarter of this year), so that works well. All is good, right?
What if something changes that necessitates a change to that modified and approved BOM? Will the next user know that the quantity adjustment was made in the BOM by virtue of it automatically being checked out when he/she checks out the assembly? Not that I know of. Therein lies the difficulty with a BOM that has to go through an approval process separately from the assembly which generated it. So - is there a way to manually create a parent-child relationship between a saved BOM and the version of the assembly that was used to create it? Other PDM systems I have used in the past do this differently and the relationship is automatically created.
Sorry for being long-winded...there was a need to give some background.
Spencer
To clarify what I said before: In calculated BOM, everything stays "hot" except for overriden quantities.
This is what makes those new virtual parts so critical, even less of a need for saved BOMs! I prefer to add a virtual item (even something like "paint") than to make a saved BOM.
(I'd go further into my raves against saved BOMs and for virtual parts, but I am already way off topic!)
I also thought that the virtual components would be a great addition, until I found out that the method for changing the quantity (so that it accurately reflects in the BOM on the SW drawing) is done in the part file properties for the virtual component. In your paint example, if you wanted to assign 2oz to one assembly, you go to File>Properties, select the variable that you assigned for BOM qty and change the number to 2. Now, anywhere you or anyone else uses 'paint', it carries the 2oz usage quantity. Makes for a workable solution if you are the only one using SW in your company, but not so good for a shared environment, which I assume if you are using PDMWE you are.
At this point, however, we are getting a little off-topic. The PDMWE 'expert' at my VAR has understood these limitations based on a couple conversations and has subequently submitted a few enhancement requests to hopefully fill in the functionality gaps. I'm just looking for workarounds in the meantime, hoping that the enhancements go through.
Spencer
Paste as reference to a parent assy makes the parent-child relationship, after that check in but keep checked out & you'll see the inclusion of the pasted part or doc in the BOM. You can adjust quantity manually by clicking off "as built" & then clicking on qty column in row of your manually attached part & adjust the qty to your need. It must be checked in to write the metadata back to the PDM parent file.
