7 Replies Latest reply on Jun 1, 2016 9:54 AM by Deepak Gupta
    DXF Export - Options
    Rafal Niczyporuk
      Hi Guys,
      Hi can I control .dxf export options using vba?
      I am using macro to export .dxf files from drawings. Some of the drawings have multiple sheets. Can I force the macro to always export with scale output enable and export all sheets to separate files.
      Any idea how control this settings using vba?
      Thanks in advance
      2016-06-01 12_17_36-SOLIDWORKS 2015 x64 Edition - [LC-1-3053 - Sheet1 [Read-only]].jpg
        • Re: DXF Export - Options
          Deepak Gupta
          API Help file has all the details/codes you need DXF/DWG Export Options
              Rafal Niczyporuk
              Hi Deepak
              Thank you for the replay
              Could you help me add the code for the options below: (  i am not sure how to do this )
              Scale 1:1 enable
              version of dxf 2002
              this is the code for dxf I am using(part of the macro)
              Private Sub DXF_Click()
              Dim swApp           As SldWorks.SldWorks
              Dim swModel         As SldWorks.ModelDoc2
              Dim swCustProp      As CustomPropertyManager
              Dim valOut          As String
              Dim resolvedValOut  As String
              Dim Filepath        As String
              Dim FileName        As String
              Dim swView          As SldWorks.View
              Set swDraw = swApp.ActiveDoc
              If swDraw Is Nothing Then Exit Sub
              If swDraw.GetType = swDocPART Then
              swApp.SendMsgToUser ("To be used for drawings only, Open a drawing first and then TRY!")
              Unload Export
              Exit Sub
              If swDraw.GetType = swDocASSEMBLY Then
              Unload Export
              Exit Sub
              If swDraw.GetPathName = "" Then
              swApp.SendMsgToUser ("Please Save SOLIDWORKS file first!")
              Unload Export
              Exit Sub
              Set swView = swDraw.GetFirstView
              Set swView = swView.GetNextView
              Set swModel = swView.ReferencedDocument
              Set swCustProp = swModel.Extension.CustomPropertyManager("")
              swCustProp.Get2 "Revision", valOut, resolvedValOut
              Filepath = TextBox1.Text
              FileName = Mid(swDraw.GetPathName, InStrRev(swDraw.GetPathName, "\") + 1)
              FileName = Left(FileName, InStrRev(FileName, ".") - 1)
              swDraw.SaveAs (Filepath + "\" + FileName + ".dxf")
              Regards
              Rafal Niczyporuk
              You are the star!!! Thank you for the help
              All works perfect
              Last question
              At the minute macro saves files as: 00_filename,  01_filename .(which 00 is sheet 1 and  01 sheet 2 and so on)..is there any easy way to move '00' after file name ? (filename_00. filename_01.)
              Thanks!
