Hi everybody
I am using sw2008
I am new to this and I would like to set up pdmworks on my computer not on a server. The reason I want it is because of revisions. I do not know how to install the vault i have pdmworks installed on my computer cause it comes with solidworks but i tried entering in my computer name and it won't except so I figure there is a specail set up option for the vault before you can start using it.
I checked the help file and there is a lot of help there but i could not find any for setting this up. So if any body can help me with this I would really apreciate it thanks in advance.
I am using sw2008
Check on your local machine to see if you have a vault installed (C:\VaultData).
My guess is that you do not. So, you need to locate the pdmserver/setup.exe
If you browse the CD there should be a folder named pdmwserver. Browse into the directory and double click on the setup.exe to install the server. IMPORTANT: Make sure you install the version of the server which matches your client.
Cheers,
Joy
