I use plane mates to locate a sub-assembly in a larger
assembly. The locating plane orientation is controled by a sketch
including a line at an angle relative to one of the principal
planes, the angle parameter is controled by an equation. The
locating plane is defined as normal to the line in the sketch.
Sometimes the locating plane doesn't follow the angle parameter
changes. I tried Ctrl-Q with no success. Does anyone else have a
similar problem. Thanks.
It could be you have some equations out of order or a "loop". To check, make a change and then Ctrl Q. If nothing happens, hit Ctrl Q again and if something happens the second time, then equation order is your problem.
