I am sure this is probably dirt simple but I can't find a
good explanation of this anywhere. I've gone through the SW
tutorial on design tables and it doesn't address it either.
I need to make the number of instances of a linear pattern variable. How do I add this to the design table? Intuition tells me I could right click on the instances text box of the pattern feature and select link value... but that's not a choice.
If you double click on your pattern in the feature manager, you will see 2 dimensions. One is the space between the pattern, the other dim is the number of repetition (hard to see sometime), right click on it, properties copy paste the full name og the dim in your DT. That's it.
