I've tested 3.0EV on my vista 64 machine at home and
performance was inferior to my XP64 machine at work. In my mind, my
home machine should be the faster of the two. I'll post specs
below. I'm wondering if anybody has fired up the newly released 3.1
on vista 64 yet and could comment on its performance. I'll be
dual-booting Vista 64 possibly as early as tomorrow here at work to
test it out.
At home:
C2D E6420@2.4 GHz
4GB DDR2 @1066 RAM
2x Geforce 8800GT (SLi)
Vista Home Premium 64-bit
At home:
C2D E6420@2.4 GHz
4GB DDR2 @1066 RAM
That being said, I believe the Q FX4500 is the equivalent of a GeForce 7800, and the 8800GT SLi setup should absolutely smoke it. Instead, that's exactly where I see performance degradation: hiccups and pauses while moving and rotating the model. This may have to do with running an OGL app inside Vista's DirectX 9 3D window manager.
I haven't done any quantitative measurements, but in general in Vista64 the Solidworks experience was noticably more jerky, fussy, and unhappy on a system which should be able to swing it without breaking a sweat.
That is exactly where differences between the Quadro and GeForce cards will show up. On professional apps, low end Quadro cards will often outperform high-end GeForce cards, even though the GeForce hardware is theoretically faster.
Secondlife
Word 2007
Excel 2007
Access 2007
Internet Explorer Live Video Feed
SW 2008 SP3.1
All going at the same time editing the largest files I could find on my machine including a 145MB complex fan clutch assembly, and this machine never choked.
Solid Works finally has a PC platform to run on. Good Job Programmers!
My Equipment:
Motherboard Abit Fatal1ity F-190HD Bios 18
Case THERMALTAKE Tsunami Dream
Power supply Thermaltake THERMALTAKE TOUGH 600W ATX 12V V2.2 / EPS W0103RU
THERMALTAKE Silent 775D CPU Cooler CL-P0378
2X Hard drive Raid 0 Seagate 250 GB SATA 2 16MB Cache ST3250410AS
1X Hard Drive JOBD Segate 250 GB SATA I 4MB
CPU Intel Core 2 Extreme Quad-Core 2.66 GHz QX6700 BX80562QX6700
Memory Corsair 2 GByte matched pair of DDR2 SDRAM DIMM TWIN2X2048-6400 5-5-5-15-2T
Vista Ultimate 64
1394a PCI Firewire Siig 3-Port NN440012S8
ATI Sapphire HD 3870 PCIe 512M GDDR4 188-01E62- 01ASA
Lexmark X4550 3-In-1 Wireless Wi Fi Printer/Copy/Scan
SW2008SP3.1
I'd expect to the Xeon 5160 to be about 20% faster than the C2D e6420. Plus, the FX4500 should be faster than the GeForce card.
Vista 64, -good, bad or ugly?
Are we /(SW) ready to jump in the Vista 64 pool and not worry about getting "bit"?
Any others?
Good, bad and or otherwise -ugly...
In my opinion Vista's time has arrived, and the O/S is at a good state. SW running on my new desktop is very responsive, and runs very smoothe. It's time to leave XP in the dust.
I use 32bit Vista on my Thinkpad I have had since December. It has been a good experience.
I have it upgraded to Vista SP1 on Tuesday and it is running well. SP1 definately addresses few of the nagging issues with file transfers which I noticed when moving files to and from my laptop.
I agree with Mike, Vista is coming into its own as a solid operating system. I would not hesitate to implement.
Going forward all the developers are going to be writing code optimized to Vista. It should only get even better moving forward.
To help you get the most out of Vista be sure to download the Tweak Guide for it. There is a ton of very good info here to help you really understand Vista's inner workings.
http://www.tweakguides.com/TGTC.html
Cheers,
By the way, there was a night-and-day difference between SW SP3.0EV and SP3.1 on my system at home. Hiccups and pausing are gone.
One word of caution though, make sure you release your SW activation before you upgrade to vista SP1. Apparently SW thinks its been copied to a new machine and refuses to start as a result.
