0 Replies Latest reply on Jun 1, 2016 2:06 AM by Andreas Olofsson
    Rotation animation - odd behavior at 180 degrees
    Andreas Olofsson
      I'm trying out animation in Visualize for the first time.
      I've added a simple rotation animation to a sphere that's initially been tilted 23,5 degrees in Z to emulate Earth's axial tilt.
      The animation consists of 100 frames. At frame 51 the model does something I can't explain. I've added no other keyframes, only a rotation animation. Could anyone shed some light on this?
      I've attached 10 frames from the animation.
      I'm not able to manually rotate the model in Y in order to re-render the odd frame. It does not end up at the same position as the animation...
      Pivot:
