I'm trying to create a surface using closed boundaries from curves and surface edges and having some problems. Please take a look at attached images and a solidworks files.
Thank you in advance!
Hei'ya Jesse,
geez Paul Salvador this looks like stalking- sorry
my take on it- same thing I guess?
att.prt file toooo
have a good'n kelef
If you use Fit Spline instead of composite curve you get rid of the tangency/curvature error. At least if you turn up the tolerance a bit.
I know it wont fit the surrounding surfaces perfectly, bur for rendering purposes it might be OK anyway. If not, you might want to rework the neighboring surfaces to fit this one.
..i created a composite curve.. (not sure why it does not want to include in selection set?)
