I HAVE A SOLID IMPELLER WITH 3 BLADES. CAN NOT FIGURE OUT WHY I CAN'T FILLET THE ROOT OF THE BLADE TO THE HUB.
Thanks for any help. Len
Len,.. can you post/attach the file here.. or a screenshot?
..it depends on the transition and the version you are using (?) but some of the fillet options (round/chord/rho) can be controlled to transition.. such as, using using a variable fillet or adding more splitlines.
Thanks Paul again, I was on the right track but I didn't select all the little items on the blade and under profile I had circular selected.
I was able to get up to .156" witch is ok for this small impeller. I guess the next session will be how to get a bigger fillet on the pressure side of the blade.
Thanks for the help
Len
Len,.. seems to work (although I did crash.. I'm not a fan of this release.. 2016sp3.. iffy ) and not sure if the radii is what you want?..
