Hi guys!
I'm working on a propeller model, and want to create some sort of reinforcement for the blade root connection with the hub.
Here is my model and an example for a propeller with the reinforcement:
A simple fillet is impossible because of the thin geometry of the blade root curve.
Any ideas/guidance/tips on how to do that?
Thanks!
Hi Shar,
Try filleting using the face-to-face option and then experiment with "constant cord" or hold lines to control the radius of your fillet as it creates itself between the bade and the hub. Otherwise, you'll have to create sketches that split the faces and then use Boundary surface or fill to create the fillet manually.
Mark
