When we went live with 2007 I applied the hot fix and all was
good. We were running Windows 2003 Server Standard addition. We
then upgraded to Windows 2003 Server R2 Standard addition and then
applied the recommended Microsoft updates. Now when I apply the hot
fix PDMWorks most of the PDMWorks options in the vault admin do not
load properly and the project folders do not load up in the
clients. If I remove the hot fix the vault service will properly
load but we are back to having vault performance going down the
drain. I am working with my VAR but so far I have no answers. Has
anyone else experienced this problem??
Is the workaround for Microsoft Hot Fix 831168 still required
for PdmWorks 2006 Sp4.2 and 2007 SP1? See the Apr 26, 2005 bulletin
on the following page for additional information.
Will you be validating it before SolidWorks World this year.
I am going to be a presenter this year. My focus will center around
PDMWorks and the Windows Server 2003 R2 will be a big part of
it.
I sent the issue to the support and QA teams - It's my
understanding that you are working with the support team. This
version has not been validated by QA to my knowledge. It may
require a new hotfix from Microsoft.
I'll let you handle this via support.
Can you attach a copy of the Help about screen - (like the one attached)
Joy
