I am trying to modify the attached files to the state that
the modified version is at, the problem is that the modified file
doesn't act right. Meaning when placed in a drawing with "hidden
lines removed" or "hidden lines visable" the outline of the file
does not show. And the extrude does not act like in the original
file. I get an error when I try to knit the surface because the
file acts as if it is already one surface.
Any ideas to what I need to do to get the modified file to act right?
Also, your surface body is already one surface, so it cannot be "knit" to anything. Try Insert>Boss>Thicken.. and choose the "create solid from enclosed volume" (also keep merge result checked). This should convert the surface body to a solid body.
