Origin does not exist
Question asked by Eric Poe on Mar 5, 2008
Latest reply on Mar 7, 2008 by Eric Poe
I went back and changed a bolt circle diameter within the hole wizard (edit feature of an existing set of holes), and upon approving the change and exiting from the hole wizard, I get a rebuild error. I go back and edit the feature again, and find that the coincident relation with the origin is dangling/unsolved. When I delete the relation and try to select the origin, Solidworks crashes and a couple of runtime error windows pop up. I then restarted solidworks, re-opened the part, deleted the two hole sets that had errors, then on the rebuild, the rest of the features get rebuild errors, all where they were referenced to the origin. Clicking on the origin in the feature tree on the left of the screen does not work, but if I click origins under the 'view' menu, it is visible in the sketch window, but I am still unable to select it.
Is this an issue with SP 3, or is there a simple solution that I am not aware of? Any help would be greatly appreciated.
Edit: this is SW 2008 x64 Edition SP 3.0
