Thanks for any help!
Title Bar Color on Tiled Windows
Hi Gerald,Gerald Davis wrote:
No, I can't tell you how to reproduce the problem, but I'd rather install SP3.57 than wait for SP4.0 with some harmonious new functionality suite that glosses over 75,000 lines of legacy experimental code.
Jim, I have a user here that has some problems with colors. Some people can have severe problems with color, and can get headaches from certain display settings. While some colors can be modified thru windows apperance, the main color of the title/borders cannot. Now that we just updated to 2008, that user could potentially have issues doing their job. I think SW should reconsider this control.Jim Wilkinson wrote:
As for the particular issue of this thread, do you consider it an issue that affects you? This is the first complaint I have heard about it through the entire release and so far only one person (the person who started the thread) has indicated that they don't like the change because the colors are too close to one another. So far, no one else has chimed in that they also think the colors are too similar so it is hard to tell how important the issue is. I assume you do agree since you mention "junk and/or goofy UI decisions" in your post but it is hard to tell if you agree it is important to fix.
Jim
At this time, there is no way for the user to adjust these colors. We could consider adjusting the colors to be more distinct from one another if many users find them to be to close to one another.
Jim
