Hey Gang;
I'm bring over some connectors that are in IGES to a solid model. Some times they will come over with out problems or I can use the import diagnostics tool and repair the gaps and faces. My question is how to use the gap closer tool to fill in gaps? I'm enclosing one of the IGES files that is giving me problems. I have saved it as a parasoil and still have problems with it.
Thank you
Thomas
Thank you
Thomas
This part comes in perfectly for me as two solid bodies in SW07 sp4.
Make sure you have your import settings correct. Import settings are cleverly hidden, so you might not find them where you think they should be. You have to open the Open dialog, then change to *.IGS or whatever file type, then the Options button appears. Make sure "Try Forming Solids" is turned on.
When you have to run Import Diagnostics, just hit the "Attempt to heal all" button. If that doesn't work, then you might have to do some manual surface modeling to get things done.
Anyway, best of luck.
