Out of memory. Multiple instances of a macro open
Question asked by Danilo Martins on May 30, 2016
I created a macro an saved it in the part file, so a equation calls it on every rebuild.
But thats my new problem, since it calls my macro on every rebuild, it remains opened! When I try to edit a macro I see a lot of instances of the macro that the equation calls opened, and consuming all my memory.
Actually I don't need that this macro runs on every rebuild. Its ok if it runs just when my file was saved, but my tries to do that doesn't works on every save. And if it don't run it can cause me serious problems.
Below my current macro. Any help?
Option Explicit
    Dim swApp               As SldWorks.SldWorks
    Dim swModel             As SldWorks.ModelDoc2
    Dim swConfigMgr         As SldWorks.ConfigurationManager
    Dim swConfig            As SldWorks.Configuration
    Dim swCustPropMgr       As SldWorks.CustomPropertyManager
    Dim valOut              As String
    Dim TIPO      As String
    Dim retval As Boolean
    Dim ALTURA As Variant
    Dim LARGURA As Variant
    Dim COMPRIMENTO As Variant
    Dim MEDIDA1 As Variant
    Dim MEDIDA2 As Variant
    Dim MEDIDA3 As Variant
    Dim DIAMETRO As Variant
    Dim CANTOS As Variant
    Set swModel = swApp.ActiveDoc
    Set swConfigMgr = swModel.ConfigurationManager
    Set swConfig = swConfigMgr.ActiveConfiguration
    'Debug.Print "Name of this configuration:" & swConfig.Name
    Set swCustPropMgr = swConfig.CustomPropertyManager
    swCustPropMgr.Get2 "TIPO", valOut, TIPO
    'MsgBox TIPO
If TIPO = "MANUAL" Or TIPO = "PERFIL" Then 'ENCERRAR PREENCHIMENTO AUTOMÁTICO
    End
If TIPO <> "TRABALHADO" And TIPO <> "CHAPA" And TIPO <> "EIXO" And TIPO <> "BRUTO" And TIPO <> "TORNEADO" And TIPO <> "BARRA QUADRADA" And TIPO <> "BARRA REDONDA" Then
    MsgBox "Tipo de fabricação não conhecido." + vbCrLf + _
            "Preencha o TIPO como uma das opções:" + vbCrLf + _
            "TRABALHADO, TORNEADO, CHAPA, EIXO, BRUTO, BARRA QUADRADA ou BARRA REDONDA" + vbCrLf + vbCrLf + _
            "Ou preecha com MANUAL para escrever manualmente conforme necessário"
    End
'MsgBox TIPO
'LER MEDIDAS
CANTOS = swModel.GetPartBox(True)         'True comes back as system units - meters
ALTURA = Round((Abs(CANTOS(4) - CANTOS(1)) * 1000), 2) ' Z axis
LARGURA = Round((Abs(CANTOS(5) - CANTOS(2)) * 1000), 2)  ' Y axis
COMPRIMENTO = Round((Abs(CANTOS(3) - CANTOS(0)) * 1000), 2) ' X axis
'ORDENAR AS DIMENSOES
If ALTURA > LARGURA Then
    If ALTURA > COMPRIMENTO Then
        MEDIDA1 = ALTURA
        If LARGURA > COMPRIMENTO Then
        MEDIDA2 = LARGURA
        MEDIDA3 = COMPRIMENTO
        Else
        MEDIDA2 = COMPRIMENTO
        MEDIDA3 = LARGURA
    Else
        MEDIDA1 = COMPRIMENTO
        MEDIDA2 = ALTURA
        MEDIDA3 = LARGURA
Else
    If COMPRIMENTO > LARGURA Then
        MEDIDA2 = LARGURA
        MEDIDA3 = ALTURA
    Else
        MEDIDA1 = LARGURA
        MEDIDA2 = ALTURA
'MsgBox MEDIDA1 & " x " & MEDIDA2 & " x " & MEDIDA3 'MOSTRAR MEDIDAS
'If TIPO <> "MANUAL" Then
    swCustPropMgr.Delete "DIMENSIONAL"
'End If
'PREENCHER DE ACORDO COM TIPO
If TIPO = "TRABALHADO" Then
    retval = swCustPropMgr.Add2("DIMENSIONAL", swCustomInfoText, _
            "t. " & MEDIDA3 & " x " & MEDIDA2 & " x " & MEDIDA1)
ElseIf TIPO = "CHAPA" Then
             "ch. " & MEDIDA3 & " x " & MEDIDA2 & " x " & MEDIDA1)  'ESCREVER VALORES
ElseIf TIPO = "EIXO" Then
    If MEDIDA1 = MEDIDA2 Then
            DIAMETRO = MEDIDA1
            COMPRIMENTO = MEDIDA3
        ElseIf MEDIDA2 = MEDIDA3 Then
            DIAMETRO = MEDIDA2
            COMPRIMENTO = MEDIDA1
        ElseIf MEDIDA1 = MEDIDA3 Then
            DIAMETRO = MEDIDA3
            COMPRIMENTO = MEDIDA2
             "Ø" & DIAMETRO & " x " & COMPRIMENTO)  'ESCREVER VALORES
ElseIf TIPO = "BRUTO" Then
             "Br. " & MEDIDA3 & " x " & MEDIDA2 & " x " & MEDIDA1)  'ESCREVER VALORES
ElseIf TIPO = "BARRA QUADRADA" Then
             "barra " & MEDIDA3 & " x " & MEDIDA2 & " x " & MEDIDA1)  'ESCREVER VALORES
ElseIf TIPO = "BARRA REDONDA" Then
            DIAMETRO = MEDIDA1
            DIAMETRO = MEDIDA2
            DIAMETRO = MEDIDA3
             "barra Ø" & DIAMETRO & " x " & COMPRIMENTO)  'ESCREVER VALORES
ElseIf TIPO = "TORNEADO" Then
            DIAMETRO = MEDIDA1
            DIAMETRO = MEDIDA2
            DIAMETRO = MEDIDA3
             "t. Ø" & DIAMETRO & " x " & COMPRIMENTO)  'ESCREVER VALORES
Else
    'MsgBox "TIPO """ & TIPO & """ NÃO CADASTRADO PARA PREENCHIMENTO DO DIMENSIONAL AUTOMÁTICO."
