Ok, I know it has been covered and there are guides here, but
I need to get it straight in my mind.
I have an administrative image installed on my server at i:\solidworks 2008\solidworks 2008 SP2 Admin Image
This I had to roll out via a batch file version of the .hta file (as it always errored out even with the right security settings - but kind of expected it the error trapping on it is "if you have an error, display the same message, even if it is nothing to do with it!")
This has worked ok on my 3 machines.
Now there is the new Service Pack.
With this installation method, I am guessing that I need to install to a new directory, then roll out with a batch file again?
Note that I didn't install via a share name, as this wasn't ever mentioned until it was too late.
Neil
Neil
But, having written that, maybe it's worth a try to rename "solidworks 2008 SP2 Admin Image" to "solidworks 2008 SP2 Admin Image-Old", then make an SP3 image in a folder called "solidworks 2008 SP2 Admin Image" (very confusing!), be sure to tell it to update any current installations, pick the "solidworks 2008 SP2 Admin Image-Old" directory when it asks for a new or existing image directory so it doesn't have to download all the files again (it will then ask you for a path to the new image directory- you'd type "solidworks 2008 SP2 Admin Image" for that) and do it's thing.
It *might* work. To be sure, have a user use start SW (not from QuickLaunch) and see if it updates after that. If it doesn't, you can delete "solidworks 2008 SP2 Admin Image" and rename -OLD back to the original state, then make "normal" SP3 images and tell people to click on the .HTA file to update manually...
Good luck! I'm curious if this works- please post back...
