Eric Snyder
Fill area in between four surfaces
Discussion created by Eric Snyder on Feb 19, 2008
Latest reply on Feb 19, 2008 by Charles Culp
I have the following shape. It was created by creating four ends and then creating a surface using either surface loft or boundary surface between each of the four ends. Each surface is colored a different color so you can tell what is going on.
I need to "fill in" the top dimple in between the four surfaces so that everything between there is smooth - almost as if this were a real part and you poured water or melted metal into the dimple. The surface would be tangent with all four of the surfaces at the top of each surface. It may or may not be a plane.
Does anybody have any ideas?
