Is there anyway to *transfer* results of cosmos from one sub-assembly to the "main assembly", so that i need not rerun analysis for the sub-assembly once again in main assy.
As far as I know only the import of motion loads is allowed in cosmosworks. Also, the Floworks can import the results from one assembly to another. But, considering your case, you have only to specify the precalculated boundary conditions manually and run the 'big' analysis without a subassy one.
Regards, Basil
