Convert this part to Sheetmetal
Discussion created by Guest on Nov 11, 2006
I took your file and had no problem converting it to sheet metal. Unfortunately I cannot send the file back (technical problems). Please go to Insert, Sheetmetal, Bends. Select the flat surface in the Cut-Extrude2->? feature and click on the green check. Unsuppress the Flat-pattern1 feature and your part should be flattened.
