what can i do with it???
From the error you are looking for a network license server you should check the following;
1. You're entry for the license server is correct.
2. The license server is working.
3. Your firewall has the appropriate ports open (Default is 25734 and 25735) check with your IT.
4. You are able to resolve the server name (DNS) try the server IP address (example - 25734@192.168.0.1).
5. If it is a standalone license you require you will need to contact the supplier of the serial number used.
See my response at Display driver 'crashing' when selecting sketch.
