I have a friend who uses Revit. He is desining a galvanized
steel pole barn frame. He see how I can render in Photoworks. What
he is wondering is there a way to bring his model into my
Solidworks so I can apply a material and render it.
I am not aware of the file output types from revit.
thanks
thanks
ACIS has different versions, so if the latest version does not work, try another version. I recently had to export a sheetmetal part from SW as an ACIS version 4.0 file so it could be imported into AutoCAD 2002 (this client did not have SW, or any other 3-D CAD software).
I will have him do that.
Hey Aaron,
I'm not a Revit user. Importing Revit models as .sat file didn't quite work for me inside SolidWorks as the model got imported as one block. I tried a trial of bimdex Revit to SolidWorks converter and was quite impressed with the results as it maintains the hierarchy and also makes rendering in SolidWorks easier. I would suggest you to get in touch with sales@bim-dex.com. They would be the best to advice on this requirement.
