I am running Solidworks 2006 and Smarteam 16. With the
Smarteam integration I have experienced a lot of crashes in
Solidworks after saving and closeing the documents. Is there a fix
for this?
I am running Solidworks 2006 and Smarteam 16. With the Smarteam
integration I have experienced a lot of crashes in Solidworks after
saving and closeing the documents. Is there a fix for this?
Hi Rodney
I don't think you will find much help about SMARTEAM matters here.
Questions about SMARTEAM has been raised here before with little or
no response. I have some SMARTEAM experience but it a bit rusty and
I can't really help you with this question.
What does your SMARTEAM VAR say about the situation? You could
check the release notes from SMARTEAM. They usually have sections
with solved and unsolved issues for each release. Maybe the SW/ST
combination you are using is not stable?
My company is running SolidWorks 2006 SP 5.0 and SMARTEAM V5
Rev 16 SP 8, and it is quite stable. As Steve asked, what SP are
you running on both programs?
I don't think you will find much help about SMARTEAM matters here. Questions about SMARTEAM has been raised here before with little or no response. I have some SMARTEAM experience but it a bit rusty and I can't really help you with this question.
What does your SMARTEAM VAR say about the situation? You could check the release notes from SMARTEAM. They usually have sections with solved and unsolved issues for each release. Maybe the SW/ST combination you are using is not stable?
You could also try http://www.smartuserforum.com/ - however I don't know if it is still operating.
