I am working on a design that is in flux. Right now, it would
be really helpful, if I could change one of my sketch dimensions to
zero. It will not let me. Are there any options that will allow
this? I really don't want to have to go into the sketch, get rid of
the dimension, change my line to vertical and then in the next 10
minutes find out that I need that dimension back and not equal to
zero. Any suggestions?
Carrie
(Solidworks 2007)
Carrie
(Solidworks 2007)
As far as I know, there isn't anything that will allow you to do that. One thing that might work is changing the line to vertical and then changing the dimension to be driven
I'm not sure if that will work for what you're trying to do but it's worth a try?
