I have a long sheet metal piece that needs a 3" wide tab every 18" down the length. Normally I would make one and do this as a sketch driven pattern, but I can't seem to replicate the sheet metal tabs this way.There will end up being roughly 30 tabs so I don't want to create them manually. None of the pattern options seem to work with the sheet metal edge flange.
It will work automatically if;
You create a small cut extrude or extend a tab just a little, then use those edges to select the edge for the edge flange tool...
