i need some help on the license manager. we are upgrading our pc's and the next one planned has the solidnetwork license manager on it. do i need to "stop" the server, and then start the server when my new pc is ready, and will this pick up from there? thanks for any advice
Hi Paul,
Presumably you will have a Solid Network License which distributes license between your computers. This will need updating separately (generally this is on a server), in order to do so run the setup application on the correct machine and select Server Products>Upgrade Solid Network License Manager. This will update the service to the latest version as required, you can then upgrade SolidWorks on the machines which should all reconnect to this SNL.
Regards,
Michael
