Odd Artifacts on Dimensions - Solidworks 2015?
Question asked by John Lega on May 26, 2016
Latest reply on May 26, 2016 by John Lega
I'm getting some odd artifacts on my dimensions (see screenshot). When I drag the dimension up and down the artifacts move with it. I have tried the following:
1. Ctrl-Q
2. Delete view then Undo
3. Change to shaded view, then back to lines hidden
4. Check all my dimension settings. Same settings I've used on all drawings and this is the only drawing affected
5. Reloaded title block
6. Closed Solidworks, Rebooted, Turned off computer and back on
7. Made sure I had latest approved drivers (nVidia K2000), even doing a clean install from safe mode
None of the above worked. When I first open the drawing it's fine but after working with it a bit they show up. It occurs on several views.
HELP!!!
